ke7o
    7
Everything posted by ke7o
  1. what about the wiring harness from the sr, would i just plug it up and get power to the srarter and an electronic fuel pump and it would go?
  2. nahh i havnt, done a compression test, could the rings be fryed? or would it be the head?
  3. ke7o
    4Kc
    What work does this evolve you doing?
  4. Hey I'm new to these corollas, and I have a 4kc in my ke70 and it's running like a dog the second last cyl is not firing, ive changed the plug and the lead and it's still not firing but it's sparking, I can pull the lead off and it will run the same at idle and revs! Is it a sticky valve or what's the problem
  5. It's a ke70! So could I use an ae71 pedal box?
  6. so i couldnt use the factory pedal box? is just want to get it in and running at the moment, its not going to be a track car..
  7. i have just brought a ke 70 and plann on doing an sr20de conversion, id like some guidence and id like to know 100% everything i need at this stage i only have the engine,box and loom! if you could help me out would be a grate help thanks :)
