Everything posted by CorollaBenny
Fuel In The Oil + Much Unburned Fuel Out Of Exsost
I have not done anything with the plugs, just changed the timing belt, and I took out the sparking plugs and removed some soot from them.
I'm going to drive it soon, but It got no lisence plates u see... But I'm going to drive it around in the neightborhood. I have just let it run warm, and when it's getting warmed up, it's nothing else than smoke coming out of the eksost pipe. But I took out the sparking plugs, cleand them, and putted them back in, but now it's coming a ticking sound somewhere. I don't know what it is, it's not from the plug cabels, because I have checked that their sitting correct and it is... I have tried to upload a video here about it, but it says that I'm not permitted to do so.
Ok, I'm not going to have the car for more that 1-2 years, but I want to find an easy and cheap solution so that I can earn from it. But I have bought alot of parts latley for this car, so I got nothing of the budget left right now. But Will it be enough for a while just to change oil? And how long will that be good?
also, is it bad for the engine to have fuel in the oil? on the internet I have read that it is, but somone is saying that it's not...
I think it's something like that too, because it ain't black, it's light gray, but what about the fuel in the oil?
Hi, I have a problem with my 95 corolla. The first problem is that it's smelling fuel from the oil when I'm checking the oil level. And also it's coming too much unburned fuel from the exsost, when I'm giving just a little throttle, and let the gas pedal go back, then the exsost start peeing, it's not like a few drops, it's alot, why? the exsost is ''peeing'' in almost 2 seconds, then it stops.... Benny
Rust In The Canals...
I'm sorry that I haven't posted any pictures yet, but it will come, but not before three weeks because I'm not going to be working on my car before that. But any1 think that I can install a new front windowshield wiper arm? I've took off the old one at school, but you guys think that I can install it with little space in the parking lot?
There are complete channels, I'll try to send a picture of them between monday and wednesday.
Also I need to know if there are any windowshield washer pump in the back of the car, because it works on the front window, but not in the back, the tube (or line or what ever) is connected, but I can't fint out what's wrong...?
I've got brand new channels, so I'll have to change the whole thing... but u got any idea of how I'm going to stiff up the car as I'm going to take off the channels?
Ok, thanks for the help, I'm sure that I'm going to ask more. if something shows up, I'll tell ya.
And if I'm only going to fix the rust marks?
How am I going to fix the hood? it is some marks on it, adn a bit of rust, but what is the easyest and cheapest way? And the same with the trunk, except that with the trunk there is cracks all over, they have not used hardener I think...
I found out of it
Hi, i've got another job too. The window viper engine needs to be changed, i've got a new one. But any1 car upload a video on how to change it? Becase i know that i'll have to tale off the glove compartment, or at least googe translate said that it's named so...?
Ok, thanks
Do I need to paint behind the channels, on the chassis? or is it just rust protection u mean?
Yeah, ok
It is those holes ur alking about, in the old channels... but I'm only going to have it one or two years after I'm turned 18, and now I'm 17, so it's not so important to do a job to make the car last for 15 years. But I will try to kill the rust inside after taking of the channels. thanks
Yeah, I know about what all the salt are doing to the car:-) And about the chassis, I don't exactly know what I shall do there... but I know that I'll need to puss away the rust, but is there anything more? And where should I look for rust?
I'm going to buy new channels anyway, just look at this! This is too bad, I have bought new channels, and going to change them at school.
To x-mas I got a rust protection mass that I'm going to use on the channels: I'm going to cut off the part with the rust, wield on a plate, and then use the rust protection over it, it is black, and the channels are black, so this should be good, don't u think?
I can see, but I try to find out how much rust there is before I buy new channels. And if it's not soo much, I'll just cut of the part with rust and weld on a bend steel plate and then put on some rust protection, I think this will help, but we'lll see how much rust it is first.
Cool, Yeah, and I'm going to polish it after all the work. I'm going to do it at school, were we have a workshop, esy to do the job with real equipment, when I don't have the chance at home:-) But any1 know any cool shift knobs that I can use in my car, any1 that u think will fit right in?
