lokie168
    36
Everything posted by lokie168
  1. @ninjamekanik, just asking questions to be sure. I just remembered a friend who said "it's better to be dumb for 5 minutes than be dumb the rest of your life"
  2. did it just went straight in? didn't have to do anything on your stock dizzy?
  3. please do greesr.
  4. thank you dust. so the kit will be containing the points or the whole dizzy itself?
  5. it's on a 35 snot. and yes it's to adjust timing. so is it really a denso?
  6. I changed the distributor and rotor cap though. not that great on details. below are the photos i took
  7. how will I know if my dizzy is a bosh one?
  8. hey dust03 will the 3BOS4U1 fit all 4k engines?
  9. hey dust03 will the 3BOS4U1 fit all 4k engines?
  10. solved the stuttering part. now will look into the speedo part.
  11. btw it idles smoothly
  12. will try to look at it or bring it to a shop. btw i'm having problems with my car. taking to long to start it. and when it runs it stutters then runs smoothly and then when i go to a full stop for a red light it stutter again then runs smoothly. do i have to correct the timing or just set the points?
  13. would this be costly time wise and money wise?
  14. was running at 80 kph and shifted to 5th gear and the speedo suddenly wasn't moving. what could be the reason? btw i have a ke35 with a 4k engine
  15. wanting to change the dizzy and changing points and condenser for a CDI.
  16. so you can use both cdi and contact point dizzy at the same time? Is it good for my 4k engine if I only use cdi?
  17. Is it okay to change the contact point type dizzy for a cdi one? what benefits will I get for this?
  18. thanks. will try it later.
  19. will it go clockwise or counter clokwise to richen the mixture?
  20. it doesn't. this just happens when it is on neutral or going to a full stop
  21. it idles okay even when it neutral. If I step on the clutch to go for 1st gear or just simply stepping on the clutch idle goes down as well as rpm. turning headlights will cause idle to go down
  22. My ke35 with a 4k stalls when I step on the clutch. need help
  23. lokie168
    Pinas Represent
    any one from Davao or philippines here? dito tayo mga boss, tulungan tayo ma pa ganda mga rolla natin. KE35 pala sa akin with a 4k engine
  24. from Davao here. Are there others from Davao or pinas here?
