ToyotaParts
  1. all dealt with,far more awkward to replace water pump than I thought.. t/y..
  2. havent done the water pump job on this kind of engine b4, to make it harder, it of course has full accessories A/c and PS.. So far, have removed front engine mounting,jack under engine lifted up a bit, alternator belt,PS belt undone bolts on water pump pulley, removed top half of timing case... Am wondering couple of issues. 1. How is PS belt usually removed/replaced, I have removed the engine mount top bracket and PS pump top support and bracket, undone WP pulley bolts only, pulley is loose , the belt can be removed with the pulley having been removed first,but how is that PS belt usually loosened and tension adjusted? 2. A/C belt..necessary removal for lower Timing Case cover? have removed alternator top adjustment bolt, .have loosened the long 13mm bolt which faces down on the idler pulley slide bracket, but this has not loosened belt tension much at all..where do you go from there for simplest A/C belt removal and replacement? 3. New WP, pump no GMB 3039...I notice comes with two O-rings about 35-40mm diam , as well as the gasket...what are they for? Water pump is not yet off ,some still stuff in the way as mentioned, so I havent fully seen what is underneath old pump. 4.while its apart like this, is T-belt replacement much simplified,are there any tricks to know with T-belt replacement?. t/y
