cellblockd
    4
About cellblockd
  • Birthday October 5
  • Location
    portland
  • Interests
    building cars, learning by doing instead of braggin after paying..projects, artwork, if your cool with other people and love your car than I'm glad to have met you.
cellblockd's Achievements
  1. Have you ever seen taka oano's corolla?
  2. hey man i have been on and off of here for a while. great progress.. your work of figuring out how to mate a 2azfe with a 3sgte bellhousing actually started my quest to convert my car (not a corolla) to an awd car with a 2azfe mated to a 3sgte based gt-four transmission. sometimes we are paying attention ;) the corolla is turning out amazing your an inspiration. keep it up
  3. I'm liking the australian enginuity, keep it up guys :party:
  4. i have to say this whole thread has been extremely helpful, funny enough i used to own an ae86 but had to sell it due to mney limitations.. but ended up buying a car here in the states with a 2az-fe in it.. i have done a lot of work on mine.. but eventually since its an awd frame with a fwd motor setup... i want to convert it to rwd.. and this has been a huge help.. especially with the crazier stuff like sourcing the transmission.. i went as far as to track down taka oano and asked a few questions about his drift corolla he put a 2az in..but eneded up finding out it was a g-force 4-speed nascar transmission.. like i can afford that right... i figured i would make an account here and thank you for all this work and being so public about it.. also i run a twin scroll evo 8 mr tdo5hr on my motor. with a tial 38mm wastagate, a forge diversion valve, 650cc injectors, 1035 treadstone fmic. had to fabricate the whole kit for it as they don't sell a twin scroll to put on the 2az-fe.. but its very worthwhile. anyhow thanks again for the info and the work you put into this, its very appreciated =) if you plan on boosting this motor i may have some stuff you will want to know.. basically odds and ends about the engine..its a great motor it just can giv you some false alarms when it comes to running boost.. p.s the aem fic is very useful when coupled with a stock ecu for this engine (inbuilt map sensor)... i street tune and as long as your careful it tunes fine.. but some of the ecu's for this motor do not have knock/ping/pinking/detonation sensor output..so its difficult to tune for knock.. so either do it with a detcan setup (electronic or not) or get a knock box and a second factory sensor and screw it on the block.. thats way you at least have some way to monitor knock.. oh and if your on a budget some of the larger lotus injectors are cross compatible and cheaper than the aftermarket ones. ok I'm out..thanks again man....and i miss my corolla...
