joseke
  1. Hello I would like to know if the front windshield from KE30 is interchangeble from ke35? They look very similar but not sure. Thanks in advance
  2. Well If the head of this engine has less combustion chamber, with flat pistons from a 3K, in this 4k, will have any problems with valves? I would like to will increase the compression ratio and get a few more HP on this 4K that´s the goal. I have a big port 3K-B head, and a twin carbs from ke35SR, and I was considering to put this in this 4K engine, to get even a few more HP. And make little more things, without spending a lot of money. King regards
  3. Hello Thank you for your answer! Yes have that two lugs on the head on that position. What does that mean? And If did not have that, what what would be the diference? Thanks in advance!!
  4. Hello I have a 4k with piston dished (with holes). Can I change to a flat ones from a 3K? Any problem with the valves? Will touch on pistons? Everything in the engine is stock. Regards
