Hayden.96
    9
Everything posted by Hayden.96
  1. Ill try it now , and the wires are the same colours so they must of kept them the same thanks mate
  2. Thanks banjo , all i could fine is the black single wire that goes to the ballast resistor well thats where it seems to go in pictures so I'm going to try and put that on to the positive side of the coil, and the carby doesnt have an wires its a 3k, so is that the only thing that it could be? And also the ignition barrel is seized but the ignition switch works fine so i can still start it and what not
  3. Thanks mate just that the guy i got the car off said thats it been wired so it doesnt need one, also he had a motor in the car and it used to start and run fine until the motor blew up hence no original motor but i might have to give it a try thanks
  4. Hey lads i have a ke55 i put a manual in it and I'm just putting it all back together and i have no reds or ignition lights i can hear the clicking sound when i turn the key but nothing else , also the dizzy is only getting spark when holding the key just past the second click on the ignition the car starts but then stalls if i back the key off? Cheers guys
  5. Also how do i bridge the auto wires for the manual gearbox? I tried to comprehend it but i can't
  6. Also could the issue with the reds be something to do with the auto seeing i put a manual in it? Its just that the only issue is no reds and the spark at the dizzy , also i don't have a ballast resistor as ive been told by the previos owner that it has been wired up so it doesnt need one
  7. Thanks banjo i havent got a ballast resistor could that be the issue? I worked out the starter motor issue but the dizzy only gets spark when its turning over on the start position but as soon as i back the key off it loses spark , i have to hold the key in a certain spot for it to spark , any help would be greatly appreciated
  8. Hey guys i have a ke55 but came with no motor do i got 3k out of a ke 10. Since i put the motor in i can't find the starter motor wire or anything to do with it I'm dumb founded. But on another note there is no ignition aswell, the reds don't come on but everything works, and also the power to the distributor only gets spark just a small turn after the second click on rhe ignition switch is that normal? Any help will be greatly appreciated!!!
