Hi guys
Ok today i created a new topic cause ive searched a lot of forums but havent really found an exact answer yet. Sorry if this may have been asked and answered before.
So today I need help with the build of a 7age/f engine. The reason I name it like that is cause it's not an 7age build. So basically what I'm doing is:
Using a 7afe block with a 4af head and 4age pistons.
Now here's what I need help with: upon doing this, which parts would I need to use. Meaning will I use the 7afe crank and rods. Will the pistons fit on this rods. Also which oil pump, water pump, tensioner and t-belt will I use. And is the crank pulley the same as the pulley of the 4af block.
Now take note that I want to use the 4af head that I already have cause I already ported and gas flowed the head. And ive done a conversion to a 32/36 dgev weber already.
Now would the be other recommendations you might have. Let's say the 2 things in definetaley gonna use is the 7afe block and 4af head. Now do you have any other recommendations as to which pistons, rods and crank I should use. Also which gasket will I use. And then upon assembly which torque setting.
Thanks guys I would really appreciate your help.
This is quite urgent as the engine is already out but before I go ahead and buy things I first need help and recomendations.
