loz181
  1. ok first post for me other than the diameter of the clutch surface area will a flywheel off a 6 /a carb engine AE90 fit a 4Af/e engine ie the crankshaft bolt holes????are they the same The reason being i scored a carb gear box which has only done 40,000klm i know the clutch splines and diameter is different but need to know whether the bolt pattern for flywheel is same thanks for your help please only reply if you know no guesses or i think so thanks
