dogbless
  1. Thanks for your help y'all. Multimeter found the issue. The first terminal from the battery lead had a dodgy connection. Previous owner had over crimped one side and it wasn't pushing together properly. Managed to wrangle it together for now and will re-fit the dodgy side properly to stop it happening again. I'm not very electrically savvy, fortunately there was a bloke there who helped me figure out where to look! All a learning process. Only a few more things left to go in getting it roadworthy. Will probably post some victory photos when the day comes. 👍 Thanks again.
  2. Hi all, My ke30 which had been running fine until the other day suddenly stopped starting. There's no sound what so ever when you turn the key, battery is fine, timing is fine, carby is getting fuel, fuses are all fine. I've ordered a new starter motor because that's all i can think of or maybe some electrical fault that means the starter isn't getting power? Any thoughts would be appreciated. Further context, It's got a 3T in it running with an old asian carby which has been rebult. Currently sitting at a radiator repair shop as they had to bypass the oringinal copper pipe valve to the heater core, don't imagine anything they were doing would have caused the issue, but who knows.
