Jarsky
  1. well finally figured it out and got it fired up today! :P dodgy wiring and connectivity on the starter motor, have fixed it and now purrin like a kitten again :fuzz:
  2. mean't I could turn the crank ok with the plugs out, I didnt really want it to ignite while I'm turning it by hand, with the propeller in the way...lol nope the plugs were completely clean apart from a little bit of oil (they were only replaced about 3 months ago), wasn't any water in there. I have to go out tonight but I will try and get the starter motor off tomorrow if I get a chance - looks like a pain in the ass where it is under the exhaust headers argh!
  3. well yesterday i pulled the plugs out and tried cranking the engine manually and it seemed to be turning. i've since bought a 2nd hand starter for $40 (incl shipping), so in the mean time i will pull this starter motor out and see what i can find...unfortunately last night i DID leave some lights on and the battery is completely dead lol - but at least if the starter motor is completely s*rewed then I have a replacement already on the way :dance: in the mean time i bought a skyline to drive around while i figure out what's wrong with this corolla so not in a rush...though the garage is looking kind of full haha. 97 rx7 coupe 71 ke25 coupe 90 r32 gts-4 coupe my accounts arent liking me right now!
  4. haha I like the way you think :hmm: I wish though.... Just bought an r32 gts-4 coupe to drive around. my rx7 still needs a clutch replacement (NZ$2800ish for parts) unfortunately don't have the funds to do a rotary conversion in the KE25 right now :yes: well I have been meaning to look at the car but have been soooo tied up organising rides to/from work and getting stuff sorted for this party tonight, but have had the car jacked up in the garage and checked out the wiring all seems to be OK, given the battery a charge off the inverter and that seems to be fine, the starter solonoid is still clicking, but I will check that out, the only other thing if its the starter could be that ive killed the starter motor somehow....can pick one up 2nd hand for about $20-30 in NZ so I might try that...if that doesnt work then ill look into the motor :dance:
  5. trying to roll start it in 2nd gear as usual, but just seems to be locking up. definately isn't the battery. fuel isnt an issue - thats coming into the carby just fine. will give that stuff a try tomorrow- its goin to be a bit hard being at the bottom of a hill but i will figure something out :) cheers for a few things to try guys. and yeah when i unbolt the starter might give it a small love tap with the hammer :hmm:
  6. cheers for reply man. its definately not the battery - ive checked that out just tried giving the starter a bit of a tap but hasn't made a difference :)
  7. what about spring spacers or are they not legal in aussie? $30-50 a set, crack the strut bolts, jack the car up to take the tension off, slip them in, lower the car back down and tighten the bolt back on... should give you just enough extra clearance to get rid of the rubbing
  8. OK first off the scenario. A few days ago, I was having problems with the starter motor on the 4K in my KE25. Got the car home, jacked it up and figured out that it was infact loose - there was only 1 bolt holding it on, and that bolt was completely undone. So tweaked it up and all was running fine. Here we are a few days later and I take the KE25 to work as I do every day (since my rx7 is broken too..its not my week). I go to grab some lunch from Subway today, which is about 4km down the road from work...car started absolutely fine, and I drive down to Subway and park up to go inside the store. Come back 5mins later to start the car, I turn the key and....nothing. Every time i turn the key I can hear a click (guess this is a starter solonoid?) however the starter motor isnt whirring or trying to do anything! I checked all the lights and stuff but thats fine, theres nothing that could possibly drain the battery that fast so I guess maybe something else wrong with the starter motor again. I checked the starter motor attached securely, starter solonoid is clicking, the coil is all hooked up and all the leads are on the spark plugs but nothing... So some nice guy tries giving me a hand to push start it, put it into 2nd...drop the clutch and it just locks up the wheels and skids to a stop... I've just now towed it home after work and tried to roll start it while being towed @ about 30-35km/h and still the wheels just lock up and skid until I let the clutch back out. Tried it again just rolling down our very steep driveway, but the wheels just lock up and the car just jumps and skids. Is a toyota 4k with a K50 (i think) 5 speed gearbox. original starter motor afaik, weber dcd carby. has a bosch coil with newish leads & ngk sparkplugs. car has plenty of coolant that I can tell, oil was just done only 1000km's ago Does anyone know what the cause could be? At first I thought perhaps wiring between the battery & the starter motor, or perhaps the starter solonoid - but even then surely it should still roll start? Was thinking maybe something has gone in the engine and its seized up, but then should the starter motor still not be trying to crank? I'm not THAT mechanical so perhaps someone that can point me in the right direction... Should I try smacking the starter motor with a hammer? :) I'm now carless until I can get this fixed as my rx7 is off the road for at least the next 3 months :hmm:
  9. have a 5 speed in my KE25 hooked up to the 3K, shitload nicer to drive with the extra gear @ 100km/h :P
  10. awesome, cheers man ;) yeah not sure what I'm doing for the booster yet - will be a 13BT conversion (cause we rock in NZ and can get away with it!!) so will probably look into a booster later down the track when I get a 13B block mocked up :(
  11. cheers guys :( I don't really want to be buying yet another master cylinder lol, am already spending plenty of $$$$ on it. Thats good info though - Jono, is that from a DC2 model integra? possible to get a pic of the setup under ur hood? also what did you do with the rear brakes, still running drums on the rear or did you upgrade the rear to disc as well? my drums are absolutely scr**ed cause of the dumbass before me putting the shoes in them the wrong way and looks like 1. It's going to be hard to source some replacement drums that fit, 2. It's going to be damn expensive too
  12. hey guys I was looking into a set of Type-RS RX7 rotors and calipers if I can fit them onto my KE25 - if not I might go a brake upgrade kit which gives me practically the same size however in both situations i need a 1" bore master cylinder. I have a brand spanking new series6 rx7 brake cylinder which I don't need for my rx7. is it possible to fit this to my KE?
  13. am modifying the rails that came with my bucket seats to fit in my KE25 - trick is making them come out looking like they came like that :) so you can't mount your seats to the existing KE35 rails?
  14. I haven't done anything to my 3K - it was modded by the previous owner. Can see in the pics though most of whats new and been fitted on. Maybe someone else can identify whats been used :)
  15. http://www.ravestyles.com/gallery-old/main...;g2_itemId=1089 heres some pics of the carby (minus the air cleaner) on my 3k
