Cra5h's Jdm Ke70 Sprinter 4k-u 1980
from Krasnodar, Krasnodarskii krai)
Soooo? long time no see)) Sprinter's gone, after a lot of diffrent cars Toyota Corona ct140 GAZ 24 Volga Supra build up but after them I got this thing Daihatsu Charmant 1986 4a-c, t50, sr5 axle) and turn it in this thing aaaand specs no motor t50, ae86 axle front suspension: mark2 gx81 lower arms + s13 hubs + s13 coilovers + 257mm*22mm brakes) rear suspension trd springs, kayaba shocks, panhard rod Section) rims Weds 6" +12 & 6.5" +5 Hoshinos 6.5" +11 & 7.5" -1 & 9" -22
Got the steering yoke and bought these rims) Advan Oni 7j +15 (for my friend's ae85) and watanabe rs8 7j+8j +38 for my supra :jamie: :yes: :bash: :bash: :bash: :bash: :bash: Seat arrived)
some pics,just for fun) new rims,rear anti-roll bar from ae86 -> -> noname seat
Small update: <_< Heater replace kit: Radiator from Lada 2107 +3m of hose and some other stuff = 40$ )))))))))))))
Thanks for comments) You can't read newspaper because it's in russian of coz))))) Yeah i used a spring compressors) I think that soon in front will be supra a70 cutted front springs) and i just must make heater because soon it got to be cold)))
JDM mirrors 13" rims??? just for drift :jamie: Installed new mirrors,and connected vacuum lines on carb Installed second seat and seatbelts Stock ae86 rear anti-roll bar Just some pics Thats all for now) Plans ofor next week is to replace heater core nearer to blower) P.S. I'm very sorry for my English :P
Place where stock radiator was mounted) I will install radiator from Lada 2106 It has mounts in the bottom,so i'll mount it in these holes)) Safety is the key))))) Rad So to install fan from carina i must drill 2 holes and make an adapter for third hole) I used this to make an adapter)) about hour of work and.... in place.. Installed the dashboard and wing mirrors) Photos:
Then another friend of mine came to garage,and they started talk)) two rims is xr4 7.5j so you can see height of the ke70 for now) I am))))) picss) i like this pic) Dashboard in process of install))
Cleanin' rims I and my friend decided to remove wings to install wing mirrors My friend Boris,owner of a supra ga70 with 1g-gte)) Then i remember "cut your springs or i'll cut your face"))) So...)
5 boxes)) My new old radio))) Rims Enkei 6j +6 off XR4 7.5j ?off Celica-Supra rims r15 6j +20
Then cleaned car from that)) Weights more than 5 kg))) Got those Enkei's 1976 year,6j +6 off Cleaning different things
Stripping off) 4k-u without head The friend of mine) Cheap parts) I got the Speedstar XR4,but they:2 rims only 7j with +12 off,and 2 rims 7.5j with ?off
Next day going to the car:wack: :P:wack: Hmmmmm,how i can name THAT...hm...a BUTTON))) Made in USSR) Wire The place where a\c hoses must be)) but luckly i don have them) Second fan connection Kolhoz style connection)) :jamie: "ВКЛ" - "ON" It works) And if you see the first 2 pics and the last you can see,that in last sun is shining)) damned Murphy law)))
Installing radiator from carina+2 fans(because ice crashed the old radiator :P )
CrA5H
