My 2 Rt40S
Yea dude Cheapskate sticker actually new fuel system fitted now, pump upgrade ti Carter silver and running old glass style filter set up
My 2 Rt40S
Whats up, Its been ages since ive updated this so though I might put a few recent pics up and a quick little catch up blurb. Also me and my mates started a facebook page for Acacia Customs so check it out, like it and watch it unfold hahahaha http://www.facebook....ustomsSpeedShop Have been driving the shit out of RAT040!!! pretty much daily driven to work and back and anywhere i need to go unless the B1800 ute is needed. Have now fully patina'd the whole car,added some web pin striping, some more acacia customs stickers and added sounds. Made new glove box from old number plates to house head unit, 2 6x9s in parcel tray and 6" in the dash and tweeters there also. Been through a few sets of tires and now have fresh white and red wall tyres. Still running 13" standards. Car is mod plated removed lowering blocks and had new leafs made with tramp bars. RAT040 is coming out of rego end of this month and I have plans to carry out some pretty extreme modifications and add some more rad shit. Been thinking what I can do to improve handling which isnt going to cost to much and hasnt been done before. Also interior upgrade and definitely staying rat rod style, all going well RAT040 will be something completely different from anything done before and should be able to get it back on the road pretty quickly. Interior: 4 x bomber style seats with 50 cal ammo boxes between seats for drink holders/armrests/storage. Ive searched and search to find bomber seats forsale which they arnt in Aus and if they are they are super pricey. So i have made my own seats, They are profile cut from 3mm ally then folded and a small amount of tigweld to stick the seat base corners together. sides are sections riveted together with plennty of rivets, brass ones to add radness. I have all 4 seats but only one fully together but with only a couple rivets so i could see final product. Currently have drilled all holes and just need to assembly them all and get railts to mount them. Roof is going to get chopped off and lowered a couple inches and welded back on. Jaguar independent rear suspension and cradle going in. Customer front suspension set up, still unsure what way to go, possibly chop complete front off and make tube frame front and weld front gaurds, bonnet, grill section all together and make it a flip front!!!!! I'm thinking this is the way to go. Also line lock kit will be fitted and other cool shit!!! Also will be rebuilding engine and giving a massive port job, upgrading gearbox to FC series 5 RX7 turbo box. Few pics of RAT040 @ Greazefest and other newer pics
My 2 Rt40S
Quick update on some new changes to car. Scored some Mitsi 15" steelies with 195/55/15 tyres for $100. Might look at some 195/50/15 or even 195/45/15 tyres Have painted one set gloss red and will get whitewalls laid on them and keep one set black for skid rims, couldnt be farked masking them out so i just used grease to cover the tyres and painted then just wipe the grease off and its all good. Rears fit fine just a small adjustment to handbrake cable so it clears the inside of the rim. Fronts foul on upper suspension arm so will need about 8mm spacers but may just keep it 13" front and 15" rears bit more ratrod/hotrod style. Also made up fuel pump and filter mounting in the boot out of one of my snapped skate decks!!!
My 2 Rt40S
Whats up just couple pics of my 2 rotors in my 3 car fleet and some pics that i was สยฉ$ษing around with some filters.
My 2 Rt40S
Whats up!! Another walk around video of RAT040 see link below!!! http://youtu.be/LLYUUwQJVUg Cheers
My 2 Rt40S
couple pics from car meet on sunday
My 2 Rt40S
Heres a clip from when i first got it running. http://www.youtube.com/watch?v=WaZXM1r47L8&list=UUCHgneDnZMdFqOb4NXGpYDw&index=1
My 2 Rt40S
Up date, Conversion is finished and RAT040 is rolling with the 13B humming and not missing a beat!!! put in a long night in the shed last night to pull it all together Got it running this morning and took it for a 150Km drive and no issues at all not even a leak!!! Yussssss
My 2 Rt40S
- My 2 Rt40S
Whats up quick update, Been getting a fair bit done lately hopefully have it running this weekend. Transmission tunnel all done. Engine mounts all done Oil pick up for reverse sump done Extractors heat wrapped Got all bits needed to make exhaust system new fittings for fuel system. Made RATROD spec gear shifter. Drive shaft being built as we speak will be ready before weekend. Just need to put it all together in the next few days so can take it for a cruise to ALL JAP DAY.- My 2 Rt40S
up date from the weekends missions, Gearbox cross member done, notched out engine cross member, fabricated new transmission tunnel and spot welded in, made engine mounts which still need to be fine tuned and welded to front cross member also fitted gilmer drives. gearbox crossy ended up being simple as = 75mm X 50mm angle iron with a notch for extractors and it bolted straight into factory cross member position notched front cross member trans tunnel fab engine mount just had mock up mounts in to get position correct, the above mounts will be cut to suit and welded onto front cross member- My 2 Rt40S
Whats up dude, You can by it off ebay from australian suppliers and also there is a couple places in brisbane that stock it- My 2 Rt40S
up date time, Got the engine sitting where I want it, ended up reversing the sump so now need to fab up new oil pick up, gearbox crossmember and make engine mount brackets. Modified the extractors that cam with the engine and they are fitting nice and snug just need to heat/exhaust wrap them and make some heat shields for steering box. I may make a complete heat shield that runs down to the collector. Also going to have to make new brake lines so they don't run so close to extractors. reversed sump, redrilled bolt holes and welded up holes not required. . Also some pics of my large extend porting template from pineapple racing in USA which i am going to add bridge ports to on the secondary and auxiliary ports so ill have a extend quad Bridgeport - all ports large extend ported then conservative bridge porting on secondary and aux ports. No need to go massive on the bridge ports as it aint no race car and id like to get a few years out of it before its needs a rebuild Also just though id add in my 4 man beer funnel, his name is Pete the Penetrator and he knows how to get the party started Also A pic of me so you can put a face to this build, hahaha- My 2 Rt40S
quick up date, Trans tunnel fully cut out and reversed the sump to give me clearance. To reverse sump I made a template of hole pattern then reversed it and drilled out new holes and welded up holes that are not required.- My 2 Rt40S
Hahaha yess sir you know how we roll!!!. Hows your epic travels going?? spotted any rad cars while on tour? - My 2 Rt40S
