4Age Carby ????
Ah true Thanks mate... so if i use the hyper pak ill be right ? I'm gunna chuck a carbs on and just see how i go....
4Age Carby ????
yeah i didnt build the motor... and the mob that did.. hav now retired... so i carnt chase that up... I'm still lookin at $2k plus be4 its runin.. I don't understand wats the go with the coil ????? a standered dizzy is a standered dizzy yeah ???? Can some 1 please explain ? I'm sure it should still REV hard and Belt tyres... Its not in a ROLLA its in a GEMINI... in which No matter if its Turbo'd or N/A... it will be different and people Like that... I'm sure ill Make some dollar bak on all my NEW gear... C.A.S,Haltech,MSD coils,turbo,Cooler,Fuel setup,Etc,Etc....
4Age Carby ????
Sorry i should hav explained my self betta... yeah it needs wiring etc few bits and pieces... and will need a tune.. I'm just not really that Crash HOT with it anymore... want a different project.. its a standered rebuild 4agze.. with cometic head gasket and head work... not sure of comp ? can that tell u anything... why carnt i just use a standered 4age Dizzy ?
4Age Carby ????
Hey all... Ive built a 4agte.. with all the goods... but ive lost interest.. and it still needs 2 be wired up etc.. i just want it runing so it moves and Can put it on the market... i was thinkin bout just throwin a dizzy bak in it.. and seting up a 32/36 weber or 350 holly on the standered GZE manifold ? So my question is.. what will it Run,Drive and under throttle be like ? Which carby should i use... ? any help will be much appreciated Thanks...
Haltech Sprint 500 / what Injectors ?
ah k true... i hav no idea about toyota motor ay.. so ur input is my output lol... i would be stocked if it makes 200rwhp.. there are plenty of questions i would like 2 ask but don't wanna look like a dik lol.. Thanks ay
hey mate... can i run both as E85 is abit far of a travel for me lol... My motor its yeah a GZE.. standered pistons,rods,crank... just done good rings,bearings and head studs.. and bought a bigport head brand new with $2300 worth of reciepts.. T4/T3 rear housing high flowed.. Big throttle etc... Can you find out the specs of your mates motor.. I'm planin on runing 25psi+
And yeah.. can i not run LOW impendence injectors at all ? Y not ?
ah thanks heaps man... so what range in OHM would be high ? and low
hey all i hav a haltech sprint 500.. and was wondering what injectors 2 run ???? I was gunna buy Delphi rochester 1000cc... But a cheap set of RC RACING 1s hav came up.. they are 1000cc also but peak and hold... So tha questions is do i run Peak and Hold OR Saturated ? oh my motor a 4agze 16v turboed ? Cheers any help appreciated..
Gze Injector Rail ?
Any where else i can get them from ???? Any idea which 1's i need ? like do they 1s for a GZE rail as they look pretty complicated
Gze Injector Rail ?
Hey all... where would i find after market injector inlet and outlet bits ? Could i just go to 2 my local performance shop ? inwhich does the Brand 'Earls' ?
what Injectors ?
yeah sweet as dude thanks...
what Injectors ?
I'm runin 2litre surge.. bosch 044,second 1 if neccesery..bigger lines, Not sure what fuel reg.. do u hav any in mind ? ah should rev rather hard yeah 8-9000rpm ? yeah planin on 1000cc carnt go wrong lol...
what Injectors ?
a mate of a mate had a celica with a 4agze turboed... and it use 2 run 35psi 24/7... i built my motor 2 his specs.. ill be rather upset if it don't get well close to 300rwhp... any help advice would be nice... thanks
what Injectors ?
hey all... i was wondering if yous could tell me what injectors would be suitable for my 4agze/turbod.. i hav so far built the motor very strong.. and hav all the goods.. i wanna run excessive boost 25-35psi... i was gunna get indy 1000cc... as for i only hav purple top rx7s lol.. which will be forsale... any help please
RND.IGO
