dirty30
    14
Everything posted by dirty30
  1. Good idea till you drive thru a puddle.I don't think water compresses very well.
  2. ill be down for a roll in the rolla.
  3. you can do a pretty good paint job urself if you strip the car right down and take ur time i just did mine and it turned out overrated and cost 300$
  4. i need to lower it then ill put sum more up
  5. yea it came out real good for a home job.
  6. just sum pics of my 55 I'm working on
  7. were abouts is the temp sender?
  8. the temp gauge in my ke55 has stoped working what could i check ?.
  9. sweet! so it will prob all just bolt on?might give it a go.
  10. Is it possable to change my square ke55 lights to the round ke30 lights i think they look nicer might go to a wrecker and see if i can find sum.
  11. problem solved thanks for the info.
  12. i was degressing the engine dident cover the dissy its not getting any spark
  13. yea its cranking over just not firering maby if i just leave it for a few days it might dry out?
  14. Hi the motor in my ke55 got wet and now it wont start ive tryed wd40 on the plugs and a few things but have had no luck what else could it be?.
  15. Hi ive just brought a ke55 and i need to no the firering order of the 4k motor thanks.
