Search the Community
Showing results for tags 'Remote Controlled Car'.
Being unable to find scale model cars, toys, replicas etc for my chosen model of Corolla, I've set about making my own. Having purchased a cheap RC car not long ago, I figured I could adapt it to suit. How do you go about replacing a mass-produced, moulded piece of plastic with one of your own shape? Build a 3D replica of what you want to make, take a mould off of it & fibreglass your own is my solution. Preferably using stuff I've had laying around for years & have 'been meaning to use'. So, Step1: Making the plug. Using leftover pieces of high-density foam & liquid nails, I made a block roughly the size/scale I needed. Using a photo editing program, adapted a few photos to suit. Printed, cut out & stuck on with contact adhesive. Hacked into shape using a hand saw. Touched up with a grinder (probably my favourite power tool, ever!). Gave it a rough sand/shape by hand, helps a lot when you've got a full sized one sitting in the driveway for reference. Then a finer grit sand to finish off & a coat of primer. Next up is a final shaping sand (some bits need some love) then bog! :D
