Search the Community
Showing results for tags 'ke55 '.
Alright, I'm new to this so please go easy. I have purchased a 1979 Toyota Corolla about 2 weeks ago. After fiddling around i have found out that the engine is actually a 3K engine. So the previous owner has tried to swap the engine over. The engine starts and runs fine. What my main concern is whether the transmission from the 4k engine is suitable to the 3k engine. Or will i need to swap over the transmission too?
Hi all, I have recently bought a 1979 KE55 corolla, it has recently been changed to a 5 speed manual (K50) from a 3sp auto (K40?) and since then the speedometer/odemeter does not work. It has the speedo cable but is missing the speedometer drive gear and key/ball in the gearbox. It is running the same diff but I'm unsure of ratio. I've think I've found the necessary parts list for transmission: http://www.toyodiy.com/parts/p_G_1979_TOYOTA_COROLLA_KE55R-EMRQ_3304.html and http://www.toyodiy.com/parts/p_G_1979_TOYOTA_COROLLA_KE55R-EMRQ_3305.html If anyone could shed a light, I don't really care if it's a little bit out as long as it works. cheers for reading!
