raceflorolla Posted December 31, 2006 Report Share Posted December 31, 2006 (edited) Hey guys, my name is sam, just wondered if anyone could help me out. I own a ke70 running a stock 4k, and recently had issues with water leaking into the combustion chambers due to corroded water jackets. So i ripped off the 4k head and bolted on a 3k-h head (i think - number 33)with a new head gasket, and extractors at the same time. Now when i try and start it, it sounds like theres no compression building up and the motors just freewheeling...i can't figure out where it would be loosing compression, and i know the timing and timing chain is fine...any ideas? Edited December 31, 2006 by raceflorolla Quote Link to comment Share on other sites More sharing options...
Robert Posted December 31, 2006 Report Share Posted December 31, 2006 Did you readjust your tappets? Did you do anything with the valves? Did the head come of an engine that you know was running? Cheers, Rob Quote Link to comment Share on other sites More sharing options...
raceflorolla Posted December 31, 2006 Author Report Share Posted December 31, 2006 I havent readjusted the tappets...but ill go do it. I didnt touch the valves when it was off, and the guy i got it off rekoned it was running but i never saw it! Sam Quote Link to comment Share on other sites More sharing options...
Robert Posted December 31, 2006 Report Share Posted December 31, 2006 I havent readjusted the tappets...but ill go do it.I didnt touch the valves when it was off, and the guy i got it off rekoned it was running but i never saw it! Sam i sold a 3k head to a guy and he did exactly what you did. the head face is lower so when you bolt it up and put the rocker gear on, the valves are held open causing no :y: compression. Cheers, Rob Quote Link to comment Share on other sites More sharing options...
raceflorolla Posted December 31, 2006 Author Report Share Posted December 31, 2006 Your a ledgend mate...you learn something new everyday :y: ...it makes sense, just didnt think of it! Quote Link to comment Share on other sites More sharing options...
