TIMTAMS Posted April 4, 2007 Report Posted April 4, 2007 How who when Has anyone done this... how easy is it? Can i get details... Need it for w55 box Thanku Grim Quote
cuzzo Posted April 4, 2007 Report Posted April 4, 2007 Theres a bit of info on here and toymods. Probably the old toymods.... http://forums.toymods.org.au/ However the most commonly used master cylinder is from the ae71. The studs are their for the master cylinder on the firewall. Just the centre hole where the push rod goes through needs to be drilled. The next hard part is modifying a clutch pedal to work with the push rod. The only way to do this is get creative, can consist of rewelding pedals or changing the pedal to a longer one maybe from a celica (possibly ta22) or similar. Quote
