Short Stroke Shockers To Suit Ke30 Struts
Hi all I thought I would share some info about short strokes to suit KE30 struts, I don't know if these would work in other models but that's irrelevant.
I went looking through a Monroe catalogue the other day at the local auto parts store.
I found that Datsun / Nissan N10 Pulsar front shocks are the go. They share the same shock design which is T1 and have the same thread for the nut that goes on top, for the curious.
They are 75mm shorter rod and 80mm shorter body, this means it requires an 80mm spacer in the bottom of the strut.
I will be using this set up when I lower Shikuza by 3 inches.
Edited by doityourself
