3tgte Wiring Diagram...
my 3tgte is in a ta22 celica and i think it just a t gearbox but on your page u say they have a w58 if i get a w58 will it bolt up thanks
  • 2 months later...
3tgte came fitted with a W55
it will bolt to the engine obviously with the 3tgte bellhousing. 1G, 1GGE, 1GGTE W bellhousing also fit a 3tgte but the clutch is on the exhaust side so will need longer clutch line and heat sheilding over the clutch slave (maybe mod exhaust to fit around it).
the clutch and driveshaft are bigger so will need to swap/mod these too. shifter position may be different depending which car the W55/W57/W58 came from. also the gearbox mount is deeper, ie it needs a lower platform to bolt to so gearbox crossmember mods required.
