TOYRLA Posted June 14, 2007 Report Share Posted June 14, 2007 hey people just wondering if the flywheel and clutch on a 86kw will fit the 100kw and what about the gear box is it all the same on the 4ages Quote Link to comment Share on other sites More sharing options...
Mr Revhead[RL] Posted June 15, 2007 Report Share Posted June 15, 2007 what model 86? bluetop? if you swap the whole fly/clutch yes it will. if its a later engine with the 42mm crank then the flywheels are the same there are differences in the boxes, but they are all interchangable, pretty much the same box. just beaware that some have 2 humps for the starter, one either side, like mouse ears. an engine with one starter hump (on the exhaust side) has a different water pipe on the back of the block when you fit a 2 hump box, the starter hump on the inlet side fouls on that pipe Quote Link to comment Share on other sites More sharing options...
