hey i am putting a ca18 into a ke 11 and want it to pull up as well as it goes.
how do you think i would go using the front struts from a ke55 in a ke11, what
would need to be done and would it make a big improvement.
thoughts & ideas are appriciated
cheers James
you need to change the front x member and the lca's to some thing with a single bar lca and with only 2 bolt holes at the bottom, take the transverse leaf out and get a sway bar kit at the same time, not really worth it, jsut take the brakes and everything off the ke55 and put it on your ke10 with some 13" wheels
