September 23, 200719 yr comment_199477 Hi guys ive been reading through and ive read about the turbo setups :P and just got a few qustions I'm running a 5k engine with liltle bit of head work done stage 2 cam and a 45mm downdraft webber 1.How do i setup the carby to handel more boost? i would like to run at least 20psi 2.recomand a stage 3 cam? and ovasized valves 3.were can i find a desent set of forgie pistions 4.would extractors be better than 70ke exhaust manifold 5.what type of ignition system would run the best on a setup like this? 6.would a 3"exhust system be better than a 2"system on a turbo setup? sorry for all the qustions ive done a seach on your forum and ive got as much info as i could :no2: Report
September 24, 200719 yr comment_199501 read all this.... http://www.rollaclub.com/board/index.php?showtopic=2341 That'll answer most of your questions :P Report
September 24, 200719 yr comment_199507 Hey Si he should buy my car and then hell get the engine as well!!!!!!!!! :P Report
