Newbie
hey guys
I'm new here, from launnie in tas.
ive got a 1984 ae71 csx with stock everything,
and just got it serviced today. the guy said the carbie needed
some work and that the electronic choke was stuffed.
is there any cheap way to fix it, like putting in a manual choke
or something like that? or should i get a whole different carbie?
any help would be good thanks.
hey guys
1 if the shaft or butterfly are worn replace the carby or the carby top.
2 if the heater coil is blown simply replace that.
or you can buy a manual choke kit from most auto parts shops with all the adapters, cable ect needed to convert to a manual choke.
yeah thanks for that. ill have a look at those 2 points you've made, but most likely will go with the manual choke. :lolcry: cheers
