Hi All,
I have a ke10, and I am about to do a front drum to disc upgrade with a set of ke20 rotors, calipers, backing plates etc..... on stock ke10 struts and stubs.
I have searched the FAQ and can not locate this detail. I wanted to know what bearings I should use;
I think from memory it was ke10 outers and ke20 inners?
Is this right?
Are there any other hidden traps like the brake lines - are they interchangable?
Thanks,
Anthony
Use ke20 disc brake wheel bearing kits.
The ke10 drum brake bearings are identical, except the seal on the back of the hub is different.
You need to change the hose from the strut bracket to caliper. Everything else is just a straight bolt up.
