February 25, 200818 yr comment_229849 howdy all, just need to no asap if ke20 super low springs will fit into ke11's??? please let me no soon as! cheers haydo Report
February 25, 200818 yr comment_229881 They will, if you remove the leaf springs. They might raise the car though. My ke16 has the leaves removed and has ke20 lowered kings springs in it. Can't remember exactly if they are lows or super lows... I'd have to check. It sits a little higher than stock. It also has ke20 upper spring seats which lower a ke1x by an inch or more. The problem with the ke1x is the spring seats are a lot closer together than what they are on a ke20. You really need a swaybar on the front if you remove the leaves. The leaves do provide a fair degree of anti-roll. Edited February 25, 200818 yr by Felix Report
February 25, 200818 yr Author comment_229933 They will, if you remove the leaf springs. They might raise the car though. My ke16 has the leaves removed and has ke20 lowered kings springs in it. Can't remember exactly if they are lows or super lows... I'd have to check. It sits a little higher than stock. It also has ke20 upper spring seats which lower a ke1x by an inch or more. The problem with the ke1x is the spring seats are a lot closer together than what they are on a ke20. You really need a swaybar on the front if you remove the leaves. The leaves do provide a fair degree of anti-roll. ok ye i atually got refered to you by scott (rol-110) to ask you first ay, so ye sounds like ill give it a miss an order customs, can't have it sittin higher now, thats not exactly what I'm going for hahah. cheers mate. :P Report
February 25, 200818 yr comment_229976 Haha - handballed! Hate to be a pain Felix, but would you mind having a quick look to see whether they are lows or superlows? I've got the ke20 strut tops waiting to drop in, and I just need to work out which Kings springs I want to put in there. Report
