I got a red top 4ag and I'm not getting any fuel out the injectors. theres plenty of fuel in the rail. and i put noid lights in the injector plugs and they work. i checked the ohms on the injectors and it reads 14.8. can anybody tell me whats wrong.? or something else i should check? is there any other way to check if the injectors are working or not? The fuel pressure regulator is good as is the fuel pump. any help, links, or anything would be HUGE! THank you.
