Wire Help Ke30 Alternator And Carby
Just need a little help
Plug 2 is Fuel Solinoid Obviously. But where does it plug into?
Plug 1 is male like the fuel one
and plug 4 is like a twin bullet female plug.
what do each of these do and where they go?
Also in circle 3, the is a nut on the alternator, what comes of that? i got the 3 pin plug in (external regulated alternator btw)
i guess it goes to battery somehow to charge it?
any help be great, ive searched, looked at pics. and it seems I'm missing some wiring??
edit, Forgot pic :hmm:
Sorry its big, just easier to see
Edited by Falken_KE30
OK I can help you here as I recently did a 7K conversion in my KE30, so I had to get intimate with the wiring. :S
Plug 4 is (surprisingly) what plugs into the fuel solenoid (Plug 2), it feeds it 12VDC with the ignition on. So that clears up those two.
The nut on the alternator should be your B+ pole, this should have a thick gauge wire connected to it using a round lug (make sure the insulator ring is present on the B+ pole, the other end should be connected to your positive (+ve) battery terminal.
The green plug (plug 1) connects to your starter loom (about 4 wires), It should have a matching green plug it connect with. If not, raid a KE30 at the wreckers for the whole starter loom. I believe it's for the starter coil.
ahhh thanks for that buddy!!!
seems cause the loom i got is from early 30, and the 4k i got is from a 55, the fuel solenoid plug on carby is a clip plug thingy, and i see on the 3k carby i got in shed its a bullet plugs, fits perfect in plug 4.
thanks again mate!
PS, you got a pic of the starter loom setup? I'm a bit lost on that
