Ke70 Radiator
Hey guys.
I've got a radiator that is leaking and basically needs to be replaced. I have one waiting to go in but it's too big:
From the one shroud hole (on the other side in the photo) to the other it's 55cm and from the support hole (where you screw it onto the front of the car) it's 60cm.
The radiator to be fitted (above) was taken off a KE70 panelvan. I'm just wondering if it's possible to find a shroud that will fit it? I'm gonna get dad to help me make up some brackets to screw the radiator onto the front of the car but yeah... need to find a shroud that will fit it. Alternatively, could I put my existing shroud (too small) onto this radiator? Does it matter that some air will escape the shroud (like 3 cms either side)?
Also found that pretty cool... I don't think I've ever had a radiator that had a drain on it...
Cheers.
Edited by Mybowlcut
