September 15, 200818 yr comment_275105 Hey guys, I've just purchased a welded diff centre for my car and I think I've run into some problems before I've even started. My car's currently running a standard open borgwarner diff with 3.9 ratio and the welded center I just bought is the 4.1 ratio'd one from the automatics. What I'm confused on is whether or not I can use the 4.1's center with crown wheel in my manual housing which still has the 3.9 pinion? In other words, can I put a diff centre which has the 4.1 crown wheel into a housing which still has the 3.9 pinion gear in it? Or will I have to change the pinion gear to the 4.1 ratio one for this new locked center to work? Cheers, Adam Edited September 15, 200818 yr by adam-__- Report
September 15, 200818 yr comment_275111 No. Use only matched crown wheel and pinions. Can't mix and match. Report
September 15, 200818 yr Author comment_275112 All I needed to know. Thanks for the quick reply. :y: Report
September 16, 200818 yr comment_275262 Haha. Try it. Will be funny. Hypoid gear sets are all matched correctly, you definitely cannot mix and match like Dwarf said. Report
