September 26, 200818 yr comment_277498 I'm looking for a vacuum hose diagram for an auto 4K engine (out of a KE55). The diagram on the bonnet of the car here has been sprayed over and is unreadable. Whoever worked on the car last decided to hook them all up their own way, blocking off some lines with a screw and putting many T pieces where there was no need for T pieces :yes: Any help you guys can give me is much appreciated. Report
September 27, 200818 yr comment_277588 its all in the Knowledge Base/FAQ had the same problem in my 70, the main ones you need are 1: from charcoal canister 2: distributor advance to carby and just try to make it look pretty from there use these pictures grasshopper http://www.rollaclub.com/faq/index.php?tit..._System_Diagram Report
September 27, 200818 yr Author comment_277595 its all in the Knowledge Base/FAQ had the same problem in my 70, the main ones you need are 1: from charcoal canister 2: distributor advance to carby and just try to make it look pretty from there use these pictures grasshopper http://www.rollaclub.com/faq/index.php?tit..._System_Diagram Thanks heaps. My car is an auto though, is there much difference? I have five metres of vacuum hose and a heap of T pieces here, so I want to get it all back to stock - at least until I decide what engine is going in there :yes: Report
September 27, 200818 yr comment_277603 I'm pretty sure it doesnt matter, man or auto. if your engine is stock (stock carby, unbroken vacuum plugs, etc) it shoudnt be a problem just study the picture and you should be right Report
September 27, 200818 yr comment_277622 I'm pretty sure it doesnt matter, man or auto It does, the auto has a stack more hoses and stuff like valves and vacume switches. Grab a manual and go to the emession section, theres a diagram in there. Report
September 29, 200818 yr comment_277898 It does, the auto has a stack more hoses and stuff like valves and vacume switches. Grab a manual and go to the emession section, theres a diagram in there. Told you to talk to these gyes didn't I. This is out of the Gregorys repair manual. Report
October 3, 200818 yr Author comment_278753 Told you to talk to these gyes didn't I. This is out of the Gregorys repair manual. That is EXACTLY what I needed. Thankyou very much. Report
October 3, 200818 yr comment_278889 That is EXACTLY what I needed. Thankyou very much. Anytime champ(Y) Report
