zilli Posted October 12, 2008 Report Posted October 12, 2008 Hey fellas, Over the last couple of fillups, ive noticed with a full tank the fuel gauge is about 3 mills under the full line... SO i have a couple of questions 1) Is it something i can adjust or fix? any ideas? 2) Does the fuel light become engaged through a sensor in the tank, or based on where the fuel light sits? Cheers Quote
Medicine_Man Posted October 12, 2008 Report Posted October 12, 2008 more likely the sender in the fuel tank is faulty.. Quote
zilli Posted October 12, 2008 Author Report Posted October 12, 2008 is the sender what triggers the fuel warnign light as well? so are bother systems (gauge/warning) one and the same? Quote
Medicine_Man Posted October 12, 2008 Report Posted October 12, 2008 yeah, should have 3 wires, common (frame), warning light and fuel level. put a jump wire from frame to both and should see light come on and full deflection of your gauge if its fine.. *gauge test* Quote
zilli Posted October 12, 2008 Author Report Posted October 12, 2008 yeah, should have 3 wires, common (frame), warning light and fuel level. put a jump wire from frame to both and should see light come on and full deflection of your gauge if its fine.. *gauge test* so the wires are off the sender? in the tank yeh?? Quote
