October 16, 200818 yr comment_281985 Hey all, Sorry if this is a really dumb question, but i haven't found anything so i thought id ask. I just blew the gearbox in my corolla, I'm not sure what type it is but its connected to a 5k now i have a 4k hi cam motor out of a ke70 wagon and was wondering if the gearbox will bolt up to the 5k engine? Also on that note will i need to remove the motor or can it be done while in the car? Cheers, Gerard Report
October 16, 200818 yr comment_281995 hey mate the gearbox form the wagon should go striaght onto the 5k however the shifter position will be abit further back so u will have to modify the shifter hole(unless the car with the 5k is a ke70 then it will be 100% fine) also I'm unsure if the tailshaft will go in to the gearbox, you can check that urself just buy removeing the tailshaft and trying to fit it in the end of the new gearbox you can change the gearbox without removeing the engine, get the car as high off the ground as possible to make it easier to work on, and when removeing the old box pull it out onto an old tyre or something. you will need a good 17 for most of the bellhouseing bolts and a 14, and possibly a 12 for the tialshaft Report
October 16, 200818 yr Author comment_282002 Hmm cutting holes.. don't like the sound of that! but if it has to be done... thanks for the input! :-) Report
