October 21, 200818 yr comment_283290 my right indicator has stopped flashing. the left one works fine but the right one when you turn it on, just stays on but does not flash. also only at the front it has completely stopped working at the back indicator. could it be the relay, if so wheres it at? cheers Report
October 21, 200818 yr comment_283334 Well if you have at least one indicator working, chances are it is not the flasher can. Have you tried to see if your hazard lights work at all? Check all your bulbs and also check the wiring connectors are all good.. Report
October 21, 200818 yr Author comment_283518 Well if you have at least one indicator working, chances are it is not the flasher can. Have you tried to see if your hazard lights work at all? Check all your bulbs and also check the wiring connectors are all good.. all good i just jiggled the globe and now it works! cheers Report
