October 31, 200817 yr comment_286133 Hey Guys I am fitting some XT130 LCAs, the Castor Arm is just .5mm out of wack and will not jsut drop in. Is there a trick? or do I NEED Castor Arms from an RT or similar??????\ Cheers MIke Report
October 31, 200817 yr comment_286205 ruely you can force it that .5mm? you mean the 2 studs that go into the LCA? you shouldnt need different ones, i didint use diffeent ones, maybe try reduceing postive caster setting to add abit more length to the rod then onces its on wind the caster back up. so short answer no you don't need any other caster rods. Edit: apologies for durnk grammar Edited October 31, 200817 yr by Shizotimang Report
November 1, 200817 yr Author comment_286274 Got it, undid a few more bolts a bit looser and Bingo, it is in Report
