DearmanKE Posted December 21, 2008 Report Share Posted December 21, 2008 ey guys i put a new 4k in my ke70, got it running and stuff then took my car for a drive and it had really bad brakes the pedal was very solid, so i thought my booster might have been f@$ked yesturday i pulled the booster out and when i pulled the master cylender away from the boost some brake fluid came out from between them asif my master had been slowly leaking from the piston bit(unsure of its technical name) it wasnt much and more fluid isnt comeing out still, anyway could this have been causeing me the brakeing problem? or could it possibly be that my booster is in fact stuffed and my master probs is half way there aswell? Quote Link to comment Share on other sites More sharing options...
SLO-030 Posted December 21, 2008 Report Share Posted December 21, 2008 Yea, fluid between master and booster would suggest leaking piston seal. most probably for the rear brakes. Id replace both of them. Just make sure you bleed them after and do it the right way :lmao: Quote Link to comment Share on other sites More sharing options...
