Calam05 Posted December 28, 2008 Report Posted December 28, 2008 my light doesnt come on when i open the door anymore, I'm thinking its the switches on the door have gotten old. the light is switched to door and it works fine when i set it to on. where can you buy new ones? or should i try my luck with the wreckers, or is there sumthing else i can do? Quote
ke20rolla Posted December 28, 2008 Report Posted December 28, 2008 I had the same problem, I just undid them out of the door frame and cleaned them up and squirted them with WD-40 to free them up so that it made good contact in the switch. ;) :y: Worked wonders. :bash: Quote
Calam05 Posted December 28, 2008 Author Report Posted December 28, 2008 i just found out my left one is stuffed, the parts have come undone, its like a pin inside the big pin. i might haveto visit the wreckers. Quote
the_random_hero Posted December 30, 2008 Report Posted December 30, 2008 A lot of Toyota ones are similar/same, so you should be able to find some easily at the wreckers. Quote
JiP Posted January 3, 2009 Report Posted January 3, 2009 Yeah, shop around in other Toyota's. Toyota liked to make a part once and use it in all their cars. Eg. Room light. I can check out my wrecks if your keen. Quote
philbey Posted January 4, 2009 Report Posted January 4, 2009 Update us with the results if you can Jip. I've seen the Narva aftermarket ones, but I'd rather something a bit less clunky. Quote
