April 11, 200521 yr comment_38756 Wanna noe tat what to mod if i put in the AE86 rear axle to my KE70... I heard tat is almost plug n play.... But some say need to mod the anti roll bar... Need to change the fuel tank or not...?? How about the Handbrake cable...?? :sad: Report
April 11, 200521 yr comment_38762 I've *heard* that it's a bolt in job. That said, I've done many "bolt in" job's that didn't exactly "bolt in", so it's a bit hard to say. AE86 and KE7x chassis are very similar, so I wouldn't think it would be difficult to change between the two. I'm guessing you're in Malaysia, and I'm guessing you're talking about the disc brake AE86 rear end. If so, then yes I believe you will need the AE86 handbrake cables too, but I think they also "bolt in" to your KE70 handbrake lever. I don't think you need to do anything with your fuel tank. Or swaybar, for that matter. Report
