Electronic Igintion For Ke70
Hello everyone.
I am new to this site, I own a '83 ke70, which is in showroom condition. I've been thinking
about converting the points to an electronic distributor set up, however am wondering
if it's worth it? and also, how can i get it done? I'm in s.a, can anyone recommend somewhere
who could do the job or even just supply the parts??
Thanks.
Hello everyone.
Thanks.
O.G. speed shop on O.G. road have installed a crane ignition system into a AE71 4AC, the change was massive, better fuel economy,more power, starts 1st go and never having to adjust points again i think the cost at the time was 280 fitted which is pretty good considering it was fitted.
I'm over adjusting points ill be getting one soon myself just to increase the reliablity of my already pretty reliable AE71.
http://www.cranecams.com/pdf/90002000a.pdf might have a go fitting it myself.
http://www.ogspeedshop.com.au/ give em call check out the site
Edited by Budowski
If it's showroom condition keep it original.
The Crane system will be a very expensive way to go.
50-100 bucks will score you a 5K distributor from this website, its a direct swap with existing and uses a Hall Effect sensor (No points to gap). Direct bolt on and 1 extra wire required from the coil.
Plenty of people here could help do the swap, would take about 1.4 beers worth of our time + travel. What area are you in?
