Ra60 Brake Upgrade
hay all i can get a hold of ra60 brakes and strutes and calipers to fit right in my ke30 is it worth it
I'm paying only 100 bucks for the two so will it make a differences as i now have a 5k in my ke30
will ra60 strutes brakes and calipers be adequit.
i can all so get a w50 gear box and a tail sharft to fit in a ke30/ke55..
but the box does'nt fit a k motor coz the bloke I'm getting it from had a celica
2l motor in the ke55.
whats the box and tail sharft wroth will i be able to sell it?? all it need is a k to w bellhouesing (rare)
cheers shaun
cheers shaun
I paid about 60 dollars for my brake calipers/rotors/struts from the wreckers shocks are stuffed and seeing as i bought them over 6 years ago infomation has just come to light i cannot use them in my AE71 but unsure if you can use them in your KE30 ???
FAQ might shed some light on struts.
i put the ra 60 conversion in my car (ke55 coupe) works sweet i was so happy till some one pointed out my mad positive camber issue, i have to do somethin with the control arms now and you need 14'' wheels to get over the calipers, obviously but thought it may help
w58 are worth a bit but to most rollaclub people its not worth the $700 bellhousings to convert the w to k or even t series bell housings best to sell it to a ( holden person ) ?
well the bloke that had them on the red ke55 had no camber issues
its all been done propley the ke55 was a hillclimb car... all i needs is maybe 4 new brake pads
and two new ra60 front disks and then its all sweet lol and it also has
pedders lowering spings on the strutes yeww..
cheers shaun
cheers shaun
I say if it all fits no issues then a RA60 brake upgrade would be a massive improment over the 30/55 brakes.
yeah ill just have to see its just they don't look that much bigger lol
nah they are alot bigger i can take a pic of a ke30 rotor up against a ra60 if you want and a AE71 rotor
yeah that would be sweet
shaun
