ke rollin 20 Posted February 15, 2009 Report Posted February 15, 2009 hey all, basically i want to no what the stock ride hight of a ke26 wagon is? I'm trying to work out how much i want it lowered as I'm trying to get onto those custom leaf springs to get made up, but, i have a problem as there are already lowering blocks in the rear leaves atm so that would change what amount i want it lowered from stock..? ya with me? so there are 1 1/2inch lowering blocks in there atm, so if i want it to be lowered 2 1 /2inche's from what it sits now then do i just subtract the 1 1/2inche's from the 2 1/2inche's then this will give me the amount that i would want it to be lowered from stock....?????? this would mean i only want it lowered 1inch.... is this right ?? if i have 1 1/2inch blocks then does it mean my stock ride hight is 1 1/2inche's higher, so the bottom of my guards would be 1 1/2inche's higher than my wheel ...? it seems alot higher... i have my doubts... give me your opinions?? cheers, haydo. Quote
dfunkt Posted February 15, 2009 Report Posted February 15, 2009 hey all, if i have 1 1/2inch blocks then does it mean my stock ride hight is 1 1/2inche's higher, so the bottom of my guards would be 1 1/2inche's higher than my wheel ...? cheers, haydo. that is correct. lowering blocks lift the diff and wheels closer to the chassis. so your stock height will mean the chassis is 1 1/2 inches higher from the ground without the blocks dF Quote
ke rollin 20 Posted February 16, 2009 Author Report Posted February 16, 2009 ok sweet cheers mate. Quote
