hey guys,
looking at doing a upgrade on my ke70..
what coilovers fit front and back? s13? r31?
also what power would a bigport 4age make?
do i need to have a external fuel pump and surge tank setup?? coz i have one lol..
cheers
S13 front coiovers will work up front if you use AE86/KE70 camber tops on them and also use S13 LCA's, hubs, brakes, etc.
As for the rear, your best using sierra shocks with cut falcon springs. Unless you want to do extensive mods to your car, you wont get rear coilover in there.
Fuel wise, you can use all of that stuff, however I JUST run a VL fuel pump, nothing else and it works fine. Expect a healthy bigport to be making around 68kW at the wheels.
They are useful, but not needed as long as you don't turn right when your tank is under quarter full.
Easy to install down the track if you need to, you can get smaller ones that will tuck up somewhere near your tank, or make your own.
