Ke70 Alternator
my ke70's alternator is not charging the battery
can anyone help
get a 2nd hand alternator or get yours recondition ? :)
Edited by drc_ke20
i think ill go do that tomoro
and its not reco'd
but thanks
and its not reco'd
but thanks
He means get yours reco'd
As in take it to an auto elecy and pay them to reco yours.
If you can use a multimeter check it all yourself, its a 90% probability that just the brushes are worn out. You can replace them yourself for about $20 with a soldering iron.
Do a few little other checks too like make sure there isnt voltage drop on the battery wire and check the earthing of it. It could save you some $$ pain.
also my charge and fuel light on the dash stopped working
if that means anything
Hey mate,
If the charge light doesn't come on then you should also check that the bulb behind it isn't blown, but with that being said the same thing happened with mine except my alternator was in good working order but it just wasn't wired in to suit it.
Maybe just try a quick wiring test to make sure it's all wired in properly. Like test to see if you have power going to the yellow wire that heads into the plug nearest the battery charge light. & also with what wires are going to the alternator 2.
Although if it was charging before & isn't now then best bet would be alternator needs reconditioning or replacing.
Good luck mate.
Tom
