April 26, 200521 yr comment_41019 Guys, I need help. The engine mounts on my KE55 are absolutely rooted. I checked with the bloke that built the car and he claimed the engine mounts were standard KE55 items, however, when I bought a set and compared them with what was left of what's in there, they were COMPLETELY different. What have you guys used in your 4AGE/4AGZE conversions. I presume that whatever is used in KE30's with this conversion will work for KE55's as well? Report
April 26, 200521 yr Author comment_41044 Would you be able to post a pic of your AE71's crossmember so I can try and work out if it has the mounts I need? Looking at mine they are like two round metal discs with a rubber in-between. Reply if you need more details (if you can't post a pic with right detail). Report
April 26, 200521 yr comment_41058 an escort/cortina engine mount is just a piece of rubber with a thread through the middle, so if you're handy, go fish two escort mounts out of the huge barrel of mounts that most wreckers have, and make your own with the stock pieces of metal. you could also lower the engine this way if you wanted Report
April 27, 200521 yr Author comment_41155 Someone else has mentioned to me that they might be Escort/Cortina mounts. And you're description sounds spot on for what's in there. Thanks! :D Report
