March 17, 200917 yr comment_328586 Hi all, I'm trying to sort out my brakes with bits I have at my disposal. I have an almost complete KE70 and hubs off a KE20. Can the KE70 calipers be used on the KE20 Discs/hubs on my KE10?? What other parts would be required?? I'm also looking at fitting the brake master out of the 70, any issues I'm likely to encounter? Thanks all. Ken Report
March 17, 200917 yr comment_328633 Gday Ken, I used KE70 discs and calipers on my KE10 using the KE20 hubs and KE30 backing plates/caliper mounts. The KE70 backing plates don't bolt straight on although you may be able to redrill the monting holes(not to sure). don't know about the master cylinder but i use a RX4 master cylinder which fits in quite nicely with very little modification and gives good pedal feel. cheers Justin Report
March 17, 200917 yr comment_328689 I used KE20 hubs with KE70 discs and calipers and KE55 backing plates. All bolted on easy as. I think the bolt pattern on the KE70 backing plate is different... Report
March 17, 200917 yr Author comment_328708 Fantastic, thanks guys. This is exactly what I wanted to hear!! :P Report
