April 10, 200917 yr comment_335392 I am trying to take out the rear seat in my 2-door KE20 but can't seem too get it out?......have removed the two lower bolts on the front of the seats but l can't see any more bolts to remove to get them out. Do l need to remove the parcel shelf to get to the other bolts or are there any special way to slide the seats out? Any help would be great, after removing the entire engine, and interior in half a day getting stopped by this is giving me the sh**s. Thanks for your help. p.s. checked int he boot too but there seems to be no bolts holding the seats in from there! Report
April 10, 200917 yr comment_335394 You need to push back the seat base and get the two hooks that the bolts bolt into over the support on the floor. To get the seat back out, there are two bolts behind the seat base that the seat belts anchor to, so undo those and slide the seat back up towards the roof and it will unhook. Report
April 10, 200917 yr Author comment_335476 You need to push back the seat base and get the two hooks that the bolts bolt into over the support on the floor. To get the seat back out, there are two bolts behind the seat base that the seat belts anchor to, so undo those and slide the seat back up towards the roof and it will unhook. Thanks Raven, will give it a go today. Report
