April 11, 200917 yr comment_335513 Got a 4age 16v, and my dizzy is leaking, have taken off cap n changed the rings as I thought that was the only problem but its not, what else could it possibly be, cause thinkin of just gettin another one but if its simple i don't wana spend the money just yet. Report
April 11, 200917 yr comment_335524 the internal seal is worn out beside the external o`ring you have replaced its is not enough to fix the problem as its leaking internally you need to buy the seal from toyota or any cbc bearing place as they sell seals too.you can do this but make sure you mark every little parts you have removed and just install in reverse order. Report
April 11, 200917 yr Author comment_335528 woahh ok, il have to go back again after long w/e, cheers mate Report
April 11, 200917 yr comment_335597 Yep, there would be 3 seals altogether. 2 important ones and it sounds like you replaced the least important one. :D The part numbers for the two seals are 'TC12379VI' and 'BS217' from CBC Bearings. Set me back $6 altogether. Links to how to change seals below. Big port dizzy: http://forums.club4ag.com/zerothread?id=8286 Small port dizzy: http://www.twincam.info/index.php?showtopic=21555 Report
June 8, 200917 yr Author comment_350642 yeh all good took it to my dads work a while back, the little seal inside was worn, fiddly as but its all good, cheers adam, that would of helped get it fixed shitload quicka, thanks Report
