Got a 4age 16v, and my dizzy is leaking, have taken off cap n changed the rings as I thought that was the only problem but its not, what else could it possibly be, cause thinkin of just gettin another one but if its simple i don't wana spend the money just yet.
the internal seal is worn out beside the external o`ring you have replaced its is not enough to fix the problem as its leaking internally
you need to buy the seal from toyota or any cbc bearing place as they sell seals too.you can do this but make sure you mark every little parts you have removed and just
install in reverse order.
Yep, there would be 3 seals altogether. 2 important ones and it sounds like you replaced the least important one. :D
The part numbers for the two seals are 'TC12379VI' and 'BS217' from CBC Bearings. Set me back $6 altogether.
Links to how to change seals below.
Big port dizzy:
http://forums.club4ag.com/zerothread?id=8286
Small port dizzy:
http://www.twincam.info/index.php?showtopic=21555
