theres a flat section on the distributor side of the block. pretty my at the rear of the engine.
Most likely you'll have a 3k, or if someones already done a swap it will probably be a 4k.
3K engine number = 3K XXX XXX
4K engine number = 4K XXX XXX
What ever the first number and letter will tell you the engine type. pretty much the same with all toyota engines, but not all.
Edited by SLO-030
